[Mapserver-dev] Problem building from CVS...
Thu Feb 12 01:08:33 EST 2004
Steve Lime wrote:
> And more, the section to set the location of libjpeg is no longer run
> before the gd code in configure.in. Looks like the GD test can never
> succeed if GD was built with jpeg support.
Steve,
That is my fault.  I moved the libjpeg test till after I know if I have
GDAL or not because I was assuming that JPEG support would only need to
be enabled if GDAL wasn't being used.  I hadn't realized the issue with
GD and use of static jpeg libraries.
I'll see what I can do to fix things back up, unless you would like to
try it.
Best regards,
