[Mapserver-dev] cpl utility functions
Wed Jul 21 17:31:28 EDT 2004
Daniel Morissette wrote:
> Yewondwossen Assefa wrote:
>>   I need to use some utility function that are available in gdal
>> cpl_xxx library. (In this specific case it is functions like
>> CPLGetBasename). At the same time, It seems a bit odd to add a
>> dependency to GDAL/OGR just to have access to a couple of functions.
>> (in this case It is the swf module and It should normally not need
>> gdal to work).
>>   What is the general guidline for such a case ? Do we need to add the
>> dependency ? Do I copy the functions inside mapserver utility files ?
> In the past we've always tried to avoid using CPL in MapServer source
> (except in code that relies on GDAL/OGR already). What I've done when I
> ran into those cases was either find another way to do the same thing,
> or implement an equivalent function (or rename and copy the CPL
> function) in mapstring.c or where it fits best.
> I'm not sure it's a good idea to create a dependency on CPL, but OTOH it
> provides several very useful utility functions that we often end up
> having to replicate... let's see what others think.
Assefa / Daniel,
My take is similar to Daniel's.  I think that for small utility functions
from CPL, you should just replicate them into mapserver.  I would
like to suggest though that:
  o We make a map_cpl.c file with morphed code.
  o We exactly change CPL to "ms" but otherwise leave the function the
    same externally so it will be easy to use and recognise for folks who
    know CPL a bit. So CPLGetBasename() would become msGetBasename().
  o When you copy over the implementation you will of course need to
    modify the code internally to use mapserver services for memory
    allocation and various macros.  Most are pretty simple.
I was going to suggest that you dump them into maputil.c, but decided not to.
Boy is that file a hodge-podge of stuff.  Why are there lots of functions
in there not starting with ms, like getMeasureUsingPoint()?
Best regards,
