[Mapserver-dev] Is there an issue in the tracker regarding new work on msImageCreate?
Yewondwossen Assefa assefa at dmsolutions.ca
Wed Jul 28 18:47:30 EDT 2004
Done (maputil.c r1.147).
Later,
Sean Gillies wrote:
> Thanks for the reply!
> Could you make changes to msImageCreate() so that it's safe to pass in
> a NULL map?  That's all I need to make it work.
> Sean
> On Jul 28, 2004, at 4:28 PM, Yewondwossen Assefa wrote:
>> I added an additional argument map object. This function was meant to
>> be a generic function to create an imageobject based on the format,
>> but it was only doing it for GD and RAWDATA. I added the other types
>> of formats that exist (IMAGEMAP, SWF, PDF), but needed a map object to
>> do that. Thus the addtion of the new argument.
>> Is this info enough to upgrade the SWIG mapscript ?
>> Later
>> Sean Gillies wrote:
>>> I'd like to discuss what's going on and learn what the
>>> scope of the work is.
>>> The change breaks a lot of stuff in the SWIG mapscript.
>>> Sean
>>> Sean Gillies
>>> sgillies at frii dot com
>>> http://users.frii.com/sgillies
>>> Mapserver-dev mailing list
>>> Mapserver-dev at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>> Assefa Yewondwossen
>> Software Analyst
>> Email: assefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax:   (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
