[Mapserver-dev] 4.2-beta2 WMS server projection problem
Sun Jun 13 23:07:40 EDT 2004
Richard Greenwood wrote:
> I am getting an error with 4.2-beta2 if I specify UTM zone 12
> (epsg:26921) in my WMS client (MapInfo 7.5). However choosing lat/lon
> NAD83 or lat/lon WGS84 does not create an error. And the same data set
> works correctly with MS 4.0 & 4.1 when I select epsg:26921. The source
> data is in state plane epsg:102758.
> I am running under Windows and tested with both IIS and Apache. Apache
> error log says:
>    "Premature end of script headers: mapserv.exe"
> I am using the UMN compiled 4.2 which requires libmap.dll & proj.dll. I
> have the LIB_PROJ environment variable set a directory with an epsg file
> containing the same definitions used successfully with MS 4.0 & 4.1
Richard,
Is this map using raster layers?  4.2-beta2 was seriously hosed for any
raster input.  Move on to 4.2 beta3 or later and things will be fine.
Best regards,
