[Mapserver-dev] Rotated Map Rendering
Wed May 19 13:37:19 EDT 2004
Steve Lime wrote:
> Hi Frank:
 > I don't think ROTATEDEXTENT makes sense either. It's the extent part
> that worries me. People are used to extents being 4 double min/max
> values and  thats not this at all. ROTATION says to me that entire view
 > is rotated n degrees, but I'm open to other ideas. I was wondering also
 > if all of the elements for the new parameter are necessary all the time.
 > Seems to me that most folks would rotate around the center of the image.
 > Also, how is with height/width here tied to the main SIZE? Wouldn't they
 > be the same most often or at least one computed from the other (i.e. so
 > the entire extent of the unrotated map fits in the rotated map, rotated
 > map would be generally larger). Folks, at least via the CGI, can easily
 > change the output map size.
Steve,
The suggested keyword is:
   ROTATEDEXTENT <center_x> <center_y> <width> <height> <rotation_angle>
Note that the width and height are in georeferenced coordinates, meters
or decimal degrees as appropriate.
The value:
   ROTATEDEXTENT 10000 50000 500 500 0
Would mean a 500m x 500m extent centered at 10000,50000 with a rotation
of zero degrees.
So, the formulation provides exactly the number of parameters needed to
define an extent and rotation angle.  Of course, the formulation of the
extent is different than the EXTENT keyword because we can't meaningful
define a rotated extent using the normal xmin/ymin/xmax/ymax format.
If the cellsize is to be square then the aspect ratio of width and height
in the ROTATEDEXTENT need to match the aspect ratio of the SIZE parameter
(final rendered image size).  This is similar to how we have do doctor
the requested EXTENT value to enforce a square cellsize now.
Now to specific questions...
Steve Lime wrote:
 > Hi Frank:
This is another way of defining an extent.  As noted above, the normal
min/max mechanism is not well defined in a rotated context but we
used the ROTATEDEXTENT in place of the regular extent and it is define
an extent rectangle that is rotated.
That would be fine if the only argument was the angle.
This is implicit in my defining the rotatedextent in terms of a center
and rotation.
I am starting to think that you expected maps to have both keywords.  My
intention is that a map could use *either* EXTENT or ROTATEDEXTENT but not
both.
PS. Implementation is now underway.  Hopefully we won't change anything too
fundamental about the approach. Of course, we can restructure the keywords
in the mapfile as you feel necessary as long as the basic data is
communicated one way or another.
Best regards,
