[Mapserver-dev] Rotated Map Rendering
Daniel Morissette dmorissette at dmsolutions.ca
Thu May 20 13:38:20 EDT 2004
Steve Lime wrote:
> Will people really be moving between rotated and non rotated worlds? The
> more
> important question is will angles change throughout the course of
> interacting with
> an app.
We could easily imagine a vehicle tracking app where the rotation of the
map is driven by the direction of the vehicule.
However, even if for apps where the rotation doesn't change, I think it
will be easier to make reusable code that works in both rotated and
non-rotated if we go with #1 since all the code deals with extents
before rotation.
(e.g. something like chameleon would have to have exceptions coded in it
to deal with scale/extents changes induced by cases #2 and 3, but Iam
hoping that #1 would save us from that)
> If so then thats a strong argument for 1. If angles are fixed
> then I still like
> 2, since at least scale would be constant from map to map.
Actually, my understanding was that only #1 would maintain scale (and
cellsize) from map to map.  With #2 or #3, the scale would vary for a
given extent depending on the rotation angle, and predicting the
resulting scale would be a complex calculation. However with #2 and #3 I
believe the scale/cellsize would be constant from map to map as long as
the rotation angle doesn't change, but would still be hard to calculate.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
