SDE raster support
Howard Butler hobu at IASTATE.EDU
Mon Nov 15 18:16:27 EST 2004
Not at this time.  Also, what was checked in this afternoon doesn't seem to
be working on my setup (ArcSDE 9.0).  It is successfully querying the
raster stuff out of the db, as judiciously planted debug statements show,
but it doesn't seem to be doing the drawing
correctly.  http://mapserver.cssm.iastate.edu/foo.jpg
I will work with this a bit tomorrow.  Hopefully I can get it to go.
Howard
At 02:40 PM 11/15/2004, Steve Lime wrote:
>Are there docs someplace on how to use it?
> >>> Frank Warmerdam <warmerdam at POBOX.COM> 11/15/2004 1:42:58 PM >>>
>  >Frank Warmerdam wrote:
> >>I notice that your version of mapsde.c does not include Howards
>recent
> >>upgrades for connection pooling support.  Hopefully it won't be too
>hard
> >>to bridge that gap.  In fact, you might want to consider preparing a
>formal
> >>patch agaist the current development tree so your changes can be
>more
> >>easiliy integrated.
>Pirmin Kalberer wrote:
> > It should be no problem. We could create a patch and test it, if the
>mapserver
> > people want to have it integrated it in the current CVS version.
>There is only
> > a absolutely minimal change in the non-raster SDE part, so I see no
>risk in
> > adding it now.
>Pirmin,
>OK, I believe Howard and I have committed the necessary pieces into the
>4.4
>tree in time for beta3 without any active resistance from our esteemed
>release manager.  Howard has agreed to be the official scape goat if
>this
>causes problems, but I would strongly encourage you to extract
>MapServer from
>CVS and do a bit of testing of the SDE raster support as commited to
>ensure it
>still works properly. I am no posisition to test it myself (or even
>build it).
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam,
>warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for
>Rent
