[Mapserver-dev] virtualising attribute data
Sean Gillies sgillies at frii.com
Thu Sep 16 13:47:35 EDT 2004
On Sep 16, 2004, at 9:58 AM, Attila Csipa wrote:
> I was thinking about the possibilities of virtualising attribute data
> for my
> needs, meaning that for example a layer that has spatial data in a
> shapefile
> has the attribute data in plain mysql (this is how it works in my
> prototype
> test and happens to be the most requested feature that I got). Note
> that this
> is _not_ the same as doing a join and not like using
> virtualspatialogr. I'd
> like to hear if anyone has some ideas or thoughts on this. Obviously
> with
> some layer types it is much harder or impossible to separate the
> spatial from
> the attribute data, and the easiest route would be to perhaps make a
> virtualxbase DBF handler, but this is not a universal solution even
> though
> this is what I think the great majority of users would use it for -
> using
> spatial data from SHP files with attributes from
> DBF/mysql/postgre/odbc/etc.
Attila,
I think that an abstract cross-database view would be best accomplished
by
some middleware
     mapserver <---- mw <----- shapefiles & mysql
and the middleware would use WFS to connect with mapserver.  Is this
idea
of any use?
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
