[Mapserver-dev] [Fwd: More MapServer test results]
Paul Ramsey pramsey at refractions.net
Mon Sep 20 11:53:03 EDT 2004
This is a multi-part message in MIME format.
--------------070102010004080405020404
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
The news just keeps getting worser and worser.
It appears that the time spent in this render is more or less evenly
split between pulling the shapes from the SDE server and rendering them
to the image.
The log below was creating by putting metering in the msDrawMap function
for vector data, which start/stop timers around layer opening (you can
see the salutary effect of the connection pooling code in action) around
WhichShapes (which is not very expensive at all) and around the drawing
loop.
For the next shape loop, I did three timers, one around the whole loop,
and two inside the loop, around the nextShape and the drawShape methods.
For the inside timers I did not do any output, I just summed up the
times and outputted them at the end, after the completion of the loop.
The "Loaded Time" is the sum of time spent in the nextShape method, and
the "Drawn Time" is the sum of time spent in the drawShape method.
ArcIMS does this map render in less than half the time Mapserver does
it. Is it possible that our superior data read speed from shape files
has been covering up an inferior render speed?
Anyhow, as I see it there are only a few explanations left
- Mapserver (gd) is just abnormally slow at rendering
   - Possibly our gd is compiled with poor or missing optimization
- Our SDE code is pulling way more data than we need, so we
   are wasting a large amount of time on data that does not
   get mapped.
- There is something terrible and mysterious about the
   windows platform that is slowing us down that has not been
   seen before because all the ArcSDE testing was on Linux/UNIX.
Any other thoughts from the gallery? Suggestions? Hints? Profiler ideas?
Content-Type: message/rfc822;
 name="More MapServer test results"
Content-Disposition: inline;
 filename="More MapServer test results"
Return-Path: <banders at refractions.net>
Received: from lion.animals ([unix socket])
	by lion.animals (Cyrus v2.1.9) with LMTP; Mon, 20 Sep 2004 08:38:31 -0700
X-Sieve: CMU Sieve 2.2
Received: by lion.animals (Postfix, from userid 88)
	id BA537E3BA; Mon, 20 Sep 2004 08:38:31 -0700 (PDT)
Received: from [192.168.50.35] (unknown [192.168.50.35])
	by lion.animals (Postfix) with ESMTP id 0F7C5E3B8
	for <pramsey at refractions.net>; Mon, 20 Sep 2004 08:38:30 -0700 (PDT)
Message-ID: <414EFAE0.5080808 at refractions.net>
Date: Mon, 20 Sep 2004 08:44:32 -0700
User-Agent: Mozilla Thunderbird 0.6 (Windows/20040502)
X-Accept-Language: en-us, en
MIME-Version: 1.0
To: Paul Ramsey <pramsey at refractions.net>
Subject: More MapServer test results
X-Spam-Checker-Version: SpamAssassin 2.63 (2004-01-11) on lion.animals
X-Spam-Status: No, hits=-6.3 required=5.0 tests=BAYES_00,UPPERCASE_25_50
	autolearn=no version=2.63
X-Spam-Level:
I used the same URL and .map file as before:
http://slkapps2.env.gov.bc.ca/mapserver/mapserv.exe?map=D:\apps_nt\bcgov\axl\LOPN_test\MapServerCommonService1.map&request=getmap&layers=BC_RIV_LAKE_WET_POLYS_500M,BC_WATER_LINES_500M,BC_TRANSPORT_LINES_500M,BC_PROV_BOUNDARIES_LINES_500M,BC_MANMADE_LINES_500M,BC_MAJOR_CITIES_POINTS_500M,BC_WATER_POINTS_500M,BC_TRANSPORT_POINTS_500M,BC_SPOT_ELEVATION_POINTS_500M,BC_MANMADE_POINTS_500M&version=1.1.1&STYLES=&SRS=EPSG:42102&BBOX=600000,800000,1500000,1300000&WIDTH=1000&HEIGHT=1000&FORMAT=PNG
Total Response time: 86452 ms
Here's the debugging output
[Mon Sep 20 08:35:02 2004] [error] [client 142.32.21.119] Mapserver
Started:
msLayerOpen(BC_RIV_LAKE_WET_POLYS_500M): Start Time: 375.000000
msLayerOpen(BC_RIV_LAKE_WET_POLYS_500M): End Time: 1187.000000
msLayerOpen(BC_RIV_LAKE_WET_POLYS_500M): Elapsed Time: 812.000000
msLayerWhichShapes(BC_RIV_LAKE_WET_POLYS_500M): Start Time: 1203.000000
msLayerWhichShapes(BC_RIV_LAKE_WET_POLYS_500M): End Time: 1265.000000
msLayerWhichShapes(BC_RIV_LAKE_WET_POLYS_500M): Elapsed Time: 62.000000
Looping on msLayerNextShape(BC_RIV_LAKE_WET_POLYS_500M): Start Time:
1265.000000
Looping on msLayerNextShape(BC_RIV_LAKE_WET_POLYS_500M): End Time:
3500.000000
Looping on msLayerNextShape(BC_RIV_LAKE_WET_POLYS_500M): Elapsed Time:
2235.000000
Shapes Loaded(BC_RIV_LAKE_WET_POLYS_500M): 2027
Shapes Loaded Time(BC_RIV_LAKE_WET_POLYS_500M): 1188.000000
Shapes Drawn(BC_RIV_LAKE_WET_POLYS_500M): 2019
Shapes Drawn Time(BC_RIV_LAKE_WET_POLYS_500M): 1047.000000
msLayerOpen(BC_WATER_LINES_500M): Start Time: 3500.000000
msLayerOpen(BC_WATER_LINES_500M): End Time: 3515.000000
msLayerOpen(BC_WATER_LINES_500M): Elapsed Time: 15.000000
msLayerWhichShapes(BC_WATER_LINES_500M): Start Time: 3531.000000
msLayerWhichShapes(BC_WATER_LINES_500M): End Time: 3734.000000
msLayerWhichShapes(BC_WATER_LINES_500M): Elapsed Time: 203.000000
Looping on msLayerNextShape(BC_WATER_LINES_500M): Start Time: 3734.000000
Looping on msLayerNextShape(BC_WATER_LINES_500M): End Time: 7969.000000
Looping on msLayerNextShape(BC_WATER_LINES_500M): Elapsed Time: 4235.000000
Shapes Loaded(BC_WATER_LINES_500M): 8872
Shapes Loaded Time(BC_WATER_LINES_500M): 1278.000000
Shapes Drawn(BC_WATER_LINES_500M): 8871
Shapes Drawn Time(BC_WATER_LINES_500M): 2877.000000
msLayerOpen(BC_TRANSPORT_LINES_500M): Start Time: 7969.000000
msLayerOpen(BC_TRANSPORT_LINES_500M): End Time: 7985.000000
msLayerOpen(BC_TRANSPORT_LINES_500M): Elapsed Time: 16.000000
msLayerWhichShapes(BC_TRANSPORT_LINES_500M): Start Time: 8000.000000
msLayerWhichShapes(BC_TRANSPORT_LINES_500M): End Time: 8047.000000
msLayerWhichShapes(BC_TRANSPORT_LINES_500M): Elapsed Time: 47.000000
Looping on msLayerNextShape(BC_TRANSPORT_LINES_500M): Start Time:
8047.000000
Looping on msLayerNextShape(BC_TRANSPORT_LINES_500M): End Time: 8625.000000
Looping on msLayerNextShape(BC_TRANSPORT_LINES_500M): Elapsed Time:
578.000000
Shapes Loaded(BC_TRANSPORT_LINES_500M): 905
Shapes Loaded Time(BC_TRANSPORT_LINES_500M): 265.000000
Shapes Drawn(BC_TRANSPORT_LINES_500M): 904
Shapes Drawn Time(BC_TRANSPORT_LINES_500M): 313.000000
msLayerOpen(BC_PROV_BOUNDARIES_LINES_500M): Start Time: 8625.000000
msLayerOpen(BC_PROV_BOUNDARIES_LINES_500M): End Time: 8641.000000
msLayerOpen(BC_PROV_BOUNDARIES_LINES_500M): Elapsed Time: 16.000000
msLayerWhichShapes(BC_PROV_BOUNDARIES_LINES_500M): Start Time: 8641.000000
msLayerWhichShapes(BC_PROV_BOUNDARIES_LINES_500M): End Time: 8672.000000
msLayerWhichShapes(BC_PROV_BOUNDARIES_LINES_500M): Elapsed Time: 31.000000
Looping on msLayerNextShape(BC_PROV_BOUNDARIES_LINES_500M): Start Time:
8672.000000
Looping on msLayerNextShape(BC_PROV_BOUNDARIES_LINES_500M): End Time:
8688.000000
Looping on msLayerNextShape(BC_PROV_BOUNDARIES_LINES_500M): Elapsed
Time: 16.000000
Shapes Loaded(BC_PROV_BOUNDARIES_LINES_500M): 34
Shapes Loaded Time(BC_PROV_BOUNDARIES_LINES_500M): 16.000000
Shapes Drawn(BC_PROV_BOUNDARIES_LINES_500M): 33
Shapes Drawn Time(BC_PROV_BOUNDARIES_LINES_500M): 0.000000
msLayerOpen(BC_MANMADE_LINES_500M): Start Time: 8688.000000
msLayerOpen(BC_MANMADE_LINES_500M): End Time: 8688.000000
msLayerOpen(BC_MANMADE_LINES_500M): Elapsed Time: 0.000000
msLayerWhichShapes(BC_MANMADE_LINES_500M): Start Time: 8703.000000
msLayerWhichShapes(BC_MANMADE_LINES_500M): End Time: 8735.000000
msLayerWhichShapes(BC_MANMADE_LINES_500M): Elapsed Time: 32.000000
Looping on msLayerNextShape(BC_MANMADE_LINES_500M): Start Time: 8735.000000
Looping on msLayerNextShape(BC_MANMADE_LINES_500M): End Time: 8766.000000
Looping on msLayerNextShape(BC_MANMADE_LINES_500M): Elapsed Time: 31.000000
Shapes Loaded(BC_MANMADE_LINES_500M): 180
Shapes Loaded Time(BC_MANMADE_LINES_500M): 31.000000
Shapes Drawn(BC_MANMADE_LINES_500M): 0
Shapes Drawn Time(BC_MANMADE_LINES_500M): 0.000000
msLayerOpen(BC_MAJOR_CITIES_POINTS_500M): Start Time: 8766.000000
msLayerOpen(BC_MAJOR_CITIES_POINTS_500M): End Time: 8781.000000
msLayerOpen(BC_MAJOR_CITIES_POINTS_500M): Elapsed Time: 15.000000
msLayerWhichShapes(BC_MAJOR_CITIES_POINTS_500M): Start Time: 8797.000000
msLayerWhichShapes(BC_MAJOR_CITIES_POINTS_500M): End Time: 8813.000000
msLayerWhichShapes(BC_MAJOR_CITIES_POINTS_500M): Elapsed Time: 16.000000
Looping on msLayerNextShape(BC_MAJOR_CITIES_POINTS_500M): Start Time:
8813.000000
Looping on msLayerNextShape(BC_MAJOR_CITIES_POINTS_500M): End Time:
8828.000000
Looping on msLayerNextShape(BC_MAJOR_CITIES_POINTS_500M): Elapsed Time:
15.000000
Shapes Loaded(BC_MAJOR_CITIES_POINTS_500M): 57
Shapes Loaded Time(BC_MAJOR_CITIES_POINTS_500M): 0.000000
Shapes Drawn(BC_MAJOR_CITIES_POINTS_500M): 56
Shapes Drawn Time(BC_MAJOR_CITIES_POINTS_500M): 15.000000
msLayerOpen(BC_WATER_POINTS_500M): Start Time: 8828.000000
msLayerOpen(BC_WATER_POINTS_500M): End Time: 8828.000000
msLayerOpen(BC_WATER_POINTS_500M): Elapsed Time: 0.000000
msLayerWhichShapes(BC_WATER_POINTS_500M): Start Time: 8844.000000
msLayerWhichShapes(BC_WATER_POINTS_500M): End Time: 8860.000000
msLayerWhichShapes(BC_WATER_POINTS_500M): Elapsed Time: 16.000000
Looping on msLayerNextShape(BC_WATER_POINTS_500M): Start Time: 8860.000000
Looping on msLayerNextShape(BC_WATER_POINTS_500M): End Time: 8860.000000
Looping on msLayerNextShape(BC_WATER_POINTS_500M): Elapsed Time: 0.000000
Shapes Loaded(BC_WATER_POINTS_500M): 5
Shapes Loaded Time(BC_WATER_POINTS_500M): 0.000000
Shapes Drawn(BC_WATER_POINTS_500M): 4
Shapes Drawn Time(BC_WATER_POINTS_500M): 0.000000
msLayerOpen(BC_TRANSPORT_POINTS_500M): Start Time: 8860.000000
msLayerOpen(BC_TRANSPORT_POINTS_500M): End Time: 8860.000000
msLayerOpen(BC_TRANSPORT_POINTS_500M): Elapsed Time: 0.000000
msLayerWhichShapes(BC_TRANSPORT_POINTS_500M): Start Time: 8875.000000
msLayerWhichShapes(BC_TRANSPORT_POINTS_500M): End Time: 8891.000000
msLayerWhichShapes(BC_TRANSPORT_POINTS_500M): Elapsed Time: 16.000000
Looping on msLayerNextShape(BC_TRANSPORT_POINTS_500M): Start Time:
8891.000000
Looping on msLayerNextShape(BC_TRANSPORT_POINTS_500M): End Time:
8906.000000
Looping on msLayerNextShape(BC_TRANSPORT_POINTS_500M): Elapsed Time:
15.000000
Shapes Loaded(BC_TRANSPORT_POINTS_500M): 33
Shapes Loaded Time(BC_TRANSPORT_POINTS_500M): 0.000000
Shapes Drawn(BC_TRANSPORT_POINTS_500M): 32
Shapes Drawn Time(BC_TRANSPORT_POINTS_500M): 15.000000
msLayerOpen(BC_SPOT_ELEVATION_POINTS_500M): Start Time: 8906.000000
msLayerOpen(BC_SPOT_ELEVATION_POINTS_500M): End Time: 8906.000000
msLayerOpen(BC_SPOT_ELEVATION_POINTS_500M): Elapsed Time: 0.000000
msLayerWhichShapes(BC_SPOT_ELEVATION_POINTS_500M): Start Time: 8922.000000
msLayerWhichShapes(BC_SPOT_ELEVATION_POINTS_500M): End Time: 10063.000000
msLayerWhichShapes(BC_SPOT_ELEVATION_POINTS_500M): Elapsed Time:
1141.000000
Looping on msLayerNextShape(BC_SPOT_ELEVATION_POINTS_500M): Start Time:
10063.000000
Looping on msLayerNextShape(BC_SPOT_ELEVATION_POINTS_500M): End Time:
54645.000000
Looping on msLayerNextShape(BC_SPOT_ELEVATION_POINTS_500M): Elapsed
Time: 44582.000000
Shapes Loaded(BC_SPOT_ELEVATION_POINTS_500M): 20967
Shapes Loaded Time(BC_SPOT_ELEVATION_POINTS_500M): 3335.000000
Shapes Drawn(BC_SPOT_ELEVATION_POINTS_500M): 20966
Shapes Drawn Time(BC_SPOT_ELEVATION_POINTS_500M): 41016.000000
msLayerOpen(BC_MANMADE_POINTS_500M): Start Time: 54645.000000
msLayerOpen(BC_MANMADE_POINTS_500M): End Time: 54660.000000
msLayerOpen(BC_MANMADE_POINTS_500M): Elapsed Time: 15.000000
msLayerWhichShapes(BC_MANMADE_POINTS_500M): Start Time: 54676.000000
msLayerWhichShapes(BC_MANMADE_POINTS_500M): End Time: 54707.000000
msLayerWhichShapes(BC_MANMADE_POINTS_500M): Elapsed Time: 31.000000
Looping on msLayerNextShape(BC_MANMADE_POINTS_500M): Start Time:
54707.000000
Looping on msLayerNextShape(BC_MANMADE_POINTS_500M): End Time: 56160.000000
Looping on msLayerNextShape(BC_MANMADE_POINTS_500M): Elapsed Time:
1453.000000
Shapes Loaded(BC_MANMADE_POINTS_500M): 315
Shapes Loaded Time(BC_MANMADE_POINTS_500M): 188.000000
Shapes Drawn(BC_MANMADE_POINTS_500M): 314
Shapes Drawn Time(BC_MANMADE_POINTS_500M): 1265.000000
--------------070102010004080405020404--
