[Mapserver-dev] Performance loss between 3.5 and 4.2
Ed Ed
Fri Sep 24 16:23:21 EDT 2004
Daniel -
That's fine, but this discussion was started because of a user question <g>!
It's relatively easy for developers to create tests to check expected changes in code they're working on, and that's certainly a good idea.  The toughest part is checking for "I pushed a button over here and performance got worse over there" problems, but certainly a first-line defense is a very good start.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
Sent: Friday, September 24, 2004 4:19 PM
To: Ed McNierney
Cc: Sean Gillies;mapserver-dev at lists.gis.umn.edu
Subject: Re: [Mapserver-dev] Performance loss between 3.5 and 4.2
Ed McNierney wrote:
> Sean -
> While I don't object to the goal, the chief difficulty is that MapServer covers such a very wide range of capabilities, with a very wide range of non-MapServer supporting libraries, that it's very difficult (IMHO) to create a test that is either comprehensive or useful.  It may be useful to have test suites to look for (a) validation of alleged performance-improving fixes or (b) changes that inadvertently cause a serious performance problem.  But the value of those suites is limited to keeping developers on their toes, not helping end users understand whether they should expect MapServer X to perform differently than MapServer Y for THEIR application - which is usually the only one they care about <g>.
We're on the -dev list here, not on the -users list.  ;)  I agree that benchmarks don't mean much to users since the performance depends on too many factors. I think what Sean is talking about is a tool for
developers: tests for typical scenarios, combined with timing measurements to automatically find out if things were broken or performance was made worse by a given change to the code. Over time as we add more tests to this suite we may end up being able to cover all aspects of the software.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
