[Mapserver-dev] Internationalization of MapServer
Daniel Morissette dmorissette at dmsolutions.ca
Mon Sep 27 11:52:51 EDT 2004
Howard Butler wrote:
> 1.  The encoding support requires the GNU iconv library.  I see that
> there is a conditional #ifdef USE_ICONV in mapgd.c to enable encodings.
> Will iconv be optional to use with MapServer?
Yes, it is optional. If you run into a situation where you are unable to
build or use the software without iconv then please file a bug and make
sure I and Julien are on the CC.
There is already one issue that Tom Kralidis reported this weekend: the
configure script doesn't seem to do the right thing for his
configuration on Fedora Core 2... Julien is trying to reproduce it on
one of our machines.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
