[Mapserver-dev] Speaking of memory leaks ...
Steve Lime steve.lime at dnr.state.mn.us
Thu Sep 30 17:24:43 EDT 2004
Thanks for all the hard work. Any clues as to the location of those
leaks? I suspect they should both be easy to fix, but I don't have
valgrind on my Mac...
Steve
>>> Sean Gillies <sgillies at frii.com> 9/27/2004 3:11:09 PM >>>
As some of you know, I've been out here on the bleeding edge of
long-running mapserver processes for a while ... and although I'm
not going to use fastcgi I am grateful for the company. :)
I'm running the Python mapscript unit tests under valgrind.  There
are pervasive leaks with msSHPOpen() and msAddLabel().  Other than
this, I'm not finding leaks in the core of mapserver.  I've cleaned
up every mapscript leak that I've found in the CVS HEAD (4.3).
Am not doing any tests with rasters or OGR.  Just shapefiles and
inline
feature layers.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
