fast-cgi
huub fleuren hfl at HOME.NL
Thu Apr 28 09:25:49 EDT 2005
Hi List,
I managed to compile mapserver4_6beta1 from cvs with the latest maporaclespatial.c
(with Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 12.00.8168 for 80x86)
using makefile.vc that comes with the source distribution 4.4.2
fcgi-2.4.0
gdal-1.2.6
gdwin32
mapserver.head
oracle10g
proj-4.4.9
regex-0.12
The resulting server works with the demodata (canada) and also a
shapefile in the used EPSG:28992
But, I get no image if i use OracleSpatial layers
compare:
(the black lines are a from a shapefile).
http://213.197.234.107/cgi-bin/mapserv-4_5/mapserv.exe?map=test.map&service=wms&request=GetMap&version=1.1.1&layers=ref1,gemeenten&srs=EPSG:28992&bbox=108557.14285714285,476500,143442.85714285714,498500&width=684&height=280&format=image/gif&transparent=TRUE
http://213.197.234.107/cgi-bin/mapserv-4_6beta/mapserv.exe?map=test.map&service=wms&request=GetMap&version=1.1.1&layers=ref1,gemeenten&srs=EPSG:28992&bbox=108557.14285714285,476500,143442.85714285714,498500&width=684&height=280&format=image/gif&transparent=TRUE
below some information
the only difference is WMS CLIENT WFS SERVER/CLIENT
i don't expect to need it
Microsoft Windows 2000 [Version 5.00.2195]
mapserv -v
MapServer version 4.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
MapServer version 4.6.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=ORACLESPATIAL
Wednesday, April 27, 2005, 2:48:49 PM, you wrote:
FS> Hi Hubb,
FS>     I saw this problem with an old version of maporaclespatial.c. But in
FS> my tests I saw that the same problem with memory occour without Oracle
FS> Spatial connection, near +0.5% (I have 512Mb in my system) for every
FS> fastcgi request.
FS>     I updated a big fix to the maporaclespatial.c in the last month, I
FS> don't know what version Bart used. But I believe that the last version
FS> can solve the memory problem. I will check the last version with
FS> fastcgis support.
FS>     About the error message, it's occour when the system can't allocate
FS> more memory to mapserver (maporaclespatial.c).
FS>     Bart, what version of maporaclespatial.c was used?
FS>     Thanks.
FS> ------------------------------------------------------------------------
FS> Fernando Simon
FS> Mapserver and Oracle Spatial developer
FS> G10 - Laboratorio de Computacao Aplicada - Brazil
FS> http://g10.cttmar.univali.br - UNIVALI/CTTMAR
FS> Huub wrote:
>> Hi list (Bart),
>> i'm looking at a few thing concerning fastcgi and oracle spatial.
>> We're using OracleSpatial10g and fastcgi in a 4.5 compile, actually it
>> was compiled by Bart van den Eijnden :-) from recent sources
>> We found that every maprefresh uses more and more memory, it's never
>> released.
>> Maybe that this has got something to do with the included error
>> fastcgi is supposed to keep open connections, but i think it does
>> something more.
>> just now i stopped apache and memoryusage dropped from 2.5Gb to 300Mb ....
>> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>> <!DOCTYPE ServiceExceptionReport SYSTEM
>> "http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException>
>> msDrawMap(): Image handling error. Failed to draw layer named
>> &#39;hn_auto&#39;.
>> msOracleSpatialLayerWhichShapes(): OracleSpatial error. *Cannot
>> allocate items buffer*
>> </ServiceException>
>> </ServiceExceptionReport>
>> i found this in the archives
>> (http://mapserver.gis.umn.edu/wilma/mapserver-dev/0409/msg00149.html)
>> where the error is 'thrown'
>> > /* allocate enough space for items */
>> > if (layer->numitems > 0) {
>> > layerinfo->items = (item_text_array *)malloc(
>> > sizeof(item_text_array) * layer->numitems );
>> > if (layerinfo->items == NULL)  {
>> > msSetError( MS_ORACLESPATIALERR,
>> > "Cannot allocate items buffer",
>> > "msOracleSpatialLayerWhichShapes()" );
>> > return MS_FAILURE;
 huub
