apostrophes and quotes inside dbf
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Mon Aug 8 03:40:26 EDT 2005
Sorry for reposting this one to all those subscribed to the mapserver
user list as well, but as I haven't yet got any feedback there I thought
it might be better to directly talk to the developers.
What I was pointing at was that dbf-records containing apostrophes or
quotes in one of their fields don't show up in an attribute query result
set when such a field is referenced inside the expression.
For instance, a query like
'[ORT_NAME_I]' =~ /.*(A|a)(N|n)(D|d)(R|r).*/
produces the expected results except for the record where ORT_NAME_I is
Sant'Andrea, which doesn't show up due to the apostrophe (things behave
exactly the same on other dbf-data, using different queries and working
on different machines, when there's char #34 or #39 around).
I guess that things go wrong somewhere inside the parser which is called
from msEvalExpression. In fact, what the parser would probably need to
do is to escape any quote and apostrophe in a string expression as
things are ok when I surround [ORT_NAME_I] in the example above with
quotes instead of apostrophes, but that vice versa hides any record
containing a quote.
Is this a bug or am I overlooking anything?
Best regards,
Andreas Albarello
Territorium Online Srl/GmbH
andreas.albarello at territoriumonline.com
www.territoriumonline.com
