GDAL/OGR - WKB
Dave Mitchell dave.mitchell at NEWGROVE.COM
Wed Aug 24 08:46:06 EDT 2005
Hi List,
I have been investigating the GDAL/OGR with the ODBC connection.
I have been using virtual data files (See the link below)
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
My understanding is as follows:
1. Non-spatial data
It is possible to plot x,y data from a SQL Server table quite easily as
follows:-
<OGRVRTDataSource>
  <OGRVRTLayer name="mylayer">
  <SrcDataSource>ODBC:mapserver/mapserver at MapServerTest</SrcDataSource>
  <SrcSQL>SELECT * FROM tblADDCAF_ADDRESS</SrcSQL>
  <GeometryField encoding="PointFromColumns" x="Easting" y="Northing"/>
  </OGRVRTLayer>
</OGRVRTDataSource>
2. WKT Spatial Data
If you have an OGC compliant WKT database with a GEOMETRY_COLUMNS table, it
is possible to plot points, Lines, polygons etc.
(It picks up the required columns automatically)
<OGRVRTDataSource>
   <OGRVRTLayer name="mylayer3">
   <SrcLayer>UK_Counties_FEA</SrcLayer>
   <GeometryType>wkbPolygon</GeometryType>
   </OGRVRTLayer>
</OGRVRTDataSource>
3. WKB Spatial Data
However the database I am using holds data in the WKB (Well Known Binary)
format and I am not clear whether this is supported by the current OGR
library as the documentations says:
"it is currently a hardcoded assumption that the geometry is in WKT format."
http://www.gdal.org/ogr/drv_odbc.html
My questions are these:-
1. Have I understood this correctly?
2. Is there a workaround for OGR with a WKB database?
3. Are there any plans to implement this functionality by GDAL/ Mapserver
and if so when?
4. If no, then who might do this custom development for a fee?
