Experimental SDE Raster support
Steve Lime steve.lime at DNR.STATE.MN.US
Thu Dec 8 13:22:33 EST 2005
Off it is!
>>> Howard Butler <hobu at IASTATE.EDU> 12/08/05 12:06 PM >>>
My call is to turn it off for now unless someone else wants to be on
the hook for it ;)
Howard
At 11:58 AM 12/8/2005, Frank Warmerdam wrote:
>On 12/8/05, Howard Butler <hobu at iastate.edu> wrote:
> > Folks,
> > I would like to comment out the experimental SDE raster support that
> > we have in mapsde.c for the time being.  As far as I know, I'm the
> > only one to ever get it to work, it hasn't kept up with the
> > connection pooling stuff we did, and its utility is quite limited in
> > comparison to regular gdal-based raster support (projections,
> > resampling, etc).
>Howard,
>Since you would be implicitly on the hook to support
>it, I think it would be your call.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
