[PATCH] Get rid of K&R style functions in sortshp.c
Petter Reinholdtsen pere at HUNGRY.COM
Mon Jan 24 03:56:48 EST 2005
The code in sortshp.c uses K&R style functions without proper
prototypes.  It is better to use ANSI C type prototypes to make sure
the compiler detect incorrect argument usage.  This patch fixes the
problem for sortshp.c.  Please include in a future version of
mapserver.
Index: sortshp.c
RCS file: /data2/cvsroot/mapserver/sortshp.c,v
retrieving revision 1.3
diff -u -r1.3 sortshp.c
--- sortshp.c   21 Oct 2004 04:30:55 -0000      1.3
+++ sortshp.c   24 Jan 2005 08:45:20 -0000
@@ -47,21 +47,21 @@
   int index;
 } sortStruct;
-static int compare_string_descending(i,j)
-sortStruct *i, *j;
+static int compare_string_descending(const void *a, const void *b)
+  const sortStruct *i = a, *j = b;
   return(strcmp(j->string, i->string));
-static int compare_string_ascending(i,j)
-sortStruct *i, *j;
+static int compare_string_ascending(const void *a, const void *b)
   return(strcmp(i->string, j->string));
-static int compare_number_descending(i,j)
-sortStruct *i, *j;
+static int compare_number_descending(const void *a, const void *b)
   if(i->number > j->number)
     return(-1);
   if(i->number < j->number)
@@ -69,9 +69,9 @@
   return(0);
-static int compare_number_ascending(i,j)
-sortStruct *i, *j;
+static int compare_number_ascending(const void *a, const void *b)
     return(1);
@@ -79,9 +79,7 @@
   return(0);
-int main(argc,argv)
-int argc;
-char *argv[];
+int main(int argc, char *argv[])
   SHPHandle    inSHP,outSHP; /* ---- Shapefile file pointers ---- */
   DBFHandle    inDBF,outDBF; /* ---- DBF file pointers ---- */
