File Descriptor Leak and Patch
Steve Lime steve.lime at DNR.STATE.MN.US
Mon Jul 11 15:29:07 EDT 2005
Thanks Steve. I'll have a look and apply the patch...
Steve
>>> Steve Wormley <steve at WORMLEY.COM> 07/09/05 2:31 PM >>>
I had a minor issue where I loaded a new(large) tiled dataset into mapserver
(using PHP/Mapscript to view) and after a few iterations the web server ran
out of file descriptors.
I don't claim to understand how the code works, but the attached patch
appears to have fixed most of the issue.
-Steve Wormley
diff -ur orig/mapserver-4.6.0/mapshape.c mapserver-4.6.0/mapshape.c
--- orig/mapserver-4.6.0/mapshape.c     2005-06-14 09:03:34.000000000 -0700
+++ mapserver-4.6.0/mapshape.c  2005-07-09 00:36:27.000000000 -0700
@@ -1715,6 +1715,7 @@
         if(strlen(filename) == 0) continue; /* check again */
         /* open the shapefile */
+       msSHPCloseFile(tSHP->shpfile);
 #ifndef IGNORE_MISSING_DATA
         if(msSHPOpenFile(tSHP->shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename)) == -1)
           if(msSHPOpenFile(tSHP->shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename)) == -1)
@@ -1785,6 +1786,7 @@
@@ -1824,6 +1826,7 @@
@@ -1897,6 +1900,7 @@
     /* open the shapefile, since a specific tile was request an error should be generated if that tile does not exist */
     if(strlen(filename) == 0) return(MS_FAILURE);
         return(MS_FAILURE);
