[UMN_MAPSERVER-USERS] Question re: PostGIS and MapScript getExtent() function
Fernando Simon fsimon at UNIVALI.BR
Wed Jul 13 10:30:45 EDT 2005
    I don't know if this issue occur in PostGIS, but sometimes when the
source of the data is a spatial function(buffer, centroid, union,
xor...) or a complex query (select with subselects and subselects...)
the Oracle Spatial don't create a spatial index for the data, so for
Oracle Spatial the function for fast Extent will return a database error
and can crash or don't return any correct value for Mapserv. Is it occur
in PostGIS?
   Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Daniel Morissette wrote:
> Paul Ramsey wrote:
>> Steve,
>> Try it on a 20M record table in Oracle. Both implementations,
>> Oracle's and your uncommented PostGIS one, do the same functional
>> thing, which is a full table scan.  It is possible that Oracle is
>> slightly smarter about reading the index for the AGGR_MBR case,
>> which  might make it work better on large tables: one for the testing
>> range.
> Since you guys wrote all the indexing code in postgis, would you not
> be able to add a function to fetch the real data extents from the
> index somehow? That would give fast and accurate responses all the
> time. Is this information not available in the data structures somewhere?
> Daniel
