Truetype Font Wrapping Patch
Andrew Seales andrew.seales at ED.AC.UK
Fri Jun 17 07:06:07 EDT 2005
We've been using Minnesota Map Server in a live WMS service for a few
months now and we have found it to be an excellent piece of software. We
have found what seems to be a small problem though. We tried using the
WRAP command inside of LAYER to specify that a text string should wrap
to the next line when it encounters a certain symbol but for some reason
we couldn't get this to work when using truetype fonts. I had a look a
the code and it seems that the line wrapping code in the bitmap font
section wasn't in the truetype font code in mapgd.c. When I added the
code into the truetype font section, then the line wrapping command
worked fine. I've attached a patch of the fix for version 4.6.0.
This is the relevant section of the mapfile:
LAYER
    NAME "Copyright"
    METADATA
        "wms_title" "Copyright"
        "wms_srs"   "EPSG:27700"
        "wms_extent"    "0.0 0.0 700000.0 1300000.0"
    END
    STATUS DEFAULT
    TRANSFORM FALSE
    TYPE ANNOTATION
    POSTLABELCACHE TRUE
    FEATURE
        POINTS
        2 5
        END
        TEXT '© Crown copyright/database right 2004.|An Ordnance
Survey/EDINA supplied service.'
    END
    CLASS
        STYLE
            SYMBOL "copy_box_os"
            COLOR 255 255 255
            SIZE 30
        END
        LABEL
            BACKGROUNDCOLOR 0 255 255
            COLOR 0 0 0
            #OUTLINECOLOR 255 255 255
            TYPE TRUETYPE
            FONT arial
            SIZE 7
            ANTIALIAS TRUE
            PARTIALS TRUE
            POSITION CR
            WRAP "|"
        END
    END
    MINSCALE 1000.0
    MAXSCALE 25000.0
    PROJECTION
        "init=epsg:27700"
    END
END # End copyright
Regards,
Andrew Seales
EDINA                   tel: +44 (0) 131 651 1430
Edinburgh University    fax: +44 (0) 131 650 3308
Main Library Building   url: http://edina.ac.uk
George Square           email: andrew.seales at ed.ac.uk
Edinburgh EH8 9LJ
--- mapgd.c	2005-06-17 11:23:23.000000000 +0100
+++ mapgd.c	2005-06-17 11:23:41.000000000 +0100
@@ -2744,6 +2744,13 @@
+    if ( label->wrap != '\0' ) {
+        char strWrap[2];
+        strWrap[0] = label->wrap;
+        strWrap[1] = '\0';
+        string = gsub( string, strWrap, "\r\n" );
     gdImageStringFT(img, bbox, ((label->antialias)?(label->color.pen):-(label->color.pen)), font, size, angle_radians, x, y, string);
     if( gdImageTrueColor(img) )
