gfs output in Maserver 4.5 using gdal1.2.5
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Tue Mar 8 16:45:24 EST 2005
Frank Warmerdam wrote:
> On Tue, 8 Mar 2005 15:47:48 -0500, Yewondwossen Assefa
> <assefa at dmsolutions.ca> wrote:
>>Hi There,
>>  I was just testing the wfs output and came accross an issue that I do
>>not really understand.  The wfs get feature request produces a gml and a
>>gfs file.  In Mapserver 4.4.X (using gdal1-2.5), the gfs contains
>>attribute informations (<PropertyDefn>) . In Mapserver 4.5 (gdal1.2.5),
>>the attributes informations are not included in the file.
>>  Does anyone has a quick explanation on this ? I am using the same test
>>map file in both cases.
> Assefa,
> This is using MapServer as a WFS server (not a client), right?
> I didn't think that MapServer itself would write out a .gfs file to
> go with a .gml result.  My understanding was that .gfs files
> are only created by OGR when opening a previously unopened
> gml file.
> I have done quite a bit of work in GDAL post-1.2.5 to support
> GML 3 Level 0 schemas, and in this case OGR is not supposed
> to create a .gfs file.  But you mention you are using GDAL 1.2.5
> in both cases, right?
> Are the GML files similar?
Frank,
I am using Mapserver as a server and a client. That exaplains my
confusion too : I understand now that Mapserver as a server produces the
gml file and when OGR is used to read the gml (for the wfs client), the
gfs file is created. Both files were created almost at the same and I
was not really thinking :)
Your are right about the diffrence in the gml file produced : I just
checked them and they are effectivly diffrent between 4.4 and 4.5. The
4.4 gml had attributes attched to it :
  <gml:featureMember>
       <popplace>
         <gml:boundedBy>
                <gml:Box srsName="EPSG:42304">
                        <gml:coordinates>
                                2281604.250000,340848.937500 2281604.250000,340848.937500
                        </gml:coordinates>
                </gml:Box>
         </gml:boundedBy>
         <gml:pointProperty>
           <gml:Point srsName="EPSG:42304">
                <gml:coordinates>2281604.250000,340848.937500</gml:coordinates>
           </gml:Point>
         </gml:pointProperty>
         <AREA>0.000</AREA>
         <PERIMETER>0.000</PERIMETER>
         <POPPLACE_>8</POPPLACE_>
         <POPPLACE_I>1</POPPLACE_I>
         <UNIQUE_KEY>BACMK</UNIQUE_KEY>
         <NAME>Tignish</NAME>
         <NAME_E></NAME_E>
         <NAME_F></NAME_F>
         <UNIQUE_K_1></UNIQUE_K_1>
         <UNIQUE_K_2></UNIQUE_K_2>
         <REG_CODE>11</REG_CODE>
         <NTS50>021I16</NTS50>
         <LAT>465700</LAT>
         <LONG>640200</LONG>
         <SGC_CODE>0</SGC_CODE>
         <CAPITAL>0</CAPITAL>
         <POP_RANGE>1</POP_RANGE>
       </popplace>
     </gml:featureMember>
  The 4.5 version does not have that :
  <gml:featureMember>
       <popplace>
         <gml:boundedBy>
                        <gml:coordinates>
                                2499190.000000,194088.234375 2499190.000000,194088.234375
                        </gml:coordinates>
                </gml:Box>
         </gml:boundedBy>
         <gml:pointProperty>
                <gml:coordinates>2499190.000000,194088.234375</gml:coordinates>
           </gml:Point>
       </popplace>
  I guess this quetion to be asked is why the new gml output in
Mapserver 4.5 does not include the attributes ? Or what should I include
to get the attributes ? I did not follow really closly the new GML
implementation (maybe I should have :)
Later,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
