WFS client problem on Windows 2003
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Mon Mar 14 10:31:29 EST 2005
Bart van den Eijnden wrote:
> 1. using the curl utility always the full document is retrieved, although
> times differ a lot between 10 and 65 seconds
> 2. Mapserver does not download the full file, it downloads a part of it,
> and the part that it downloads differs all the time.
Did you try increating the wfs_connectiontimeout metadata value? The
default is 30 seconds. If the response from your WFS takes more than 30
seconds to arrive then the transfer could be aborted and that could
explain the behavior that you've seen.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
