WFS client problem on Windows 2003, conti nued
Ned Harding nharding at EXTENDTHEREACH.COM
Mon Mar 14 15:09:02 EST 2005
Sorry, I don't actually have the latest code on my machine...  Due to how MS
changed IIS around, it would probably have the same affect on the argv[0]
I don't know if MapServer uses it either, sorry.  Really the only reason I
mentioned this at all is because is is the one major difference we have
found with IIS on win2003 and XP SP2.
Ned.
-----Original Message-----
From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
Sent: Monday, March 14, 2005 9:17 AM
To: Ned Harding; MAPSERVER-DEV at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-DEV] WFS client problem on Windows 2003, conti
nued
Hi Ned,
thanks for your reply.
But there is no call in the Mapserver source code to the GetModuleFileName
function, so how could this be the cause?
Best regards,
Bart
On Mon, 14 Mar 2005 09:14:52 -0700, Ned Harding
<nharding at extendthereach.com> wrote:
> No idea if it is related to your problem or not, but if you are using
> IIS on Win2003, any calls to GetModuleFileName will prepend "\\?\" to
> the front of the path...  It caused havok in a bunch of our code until
> we figured out what was going on and striuped it off.  You get the
> same problem with IIS on XP SP2.  See the docs for GetModuleFileName:
> http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dllpr
> oc/bas
> e/getmodulefilename.asp
> Ned.
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
> On
> Behalf Of Bart van den Eijnden
> Sent: Monday, March 14, 2005 8:09 AM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-DEV] WFS client problem on Windows 2003,
> continued
> Hi list,
> I just got some more info about this. Strangely enough everything
> works fine in application (non-CGI) mode, i.e. running mapserv from
> the command-line with QUERY_STRING.
> This is the output created, including libcurl debug output. There is a
> section where the mapserv process waits for a while, but after that
> continues. That section is marked in the output with a lot of *******.
> Does anybody see something strange? Or does somebody see a reason why
> this would work in application mode, but not in CGI mode?
> In total there are 3 WFS client layers.
> Thanks in advance.
> Best regards,
> Bart
> On Mon, 14 Mar 2005 14:26:29 +0100, Bart van den Eijnden
> <bartvde at xs4all.nl>
> wrote:
>> Hi list,
>> does anybody have an idea what could be causing the following
>> behaviour in Mapserver WFS client?
>> We were testing a URL to an external WFS service (intranet) on
>> Windows 2003.
>> 1. using the curl utility always the full document is retrieved,
>> although times differ a lot between 10 and 65 seconds
>> 2. Mapserver does not download the full file, it downloads a part of
>> it, and the part that it downloads differs all the time.
>> 3. In IIS 6 a CGI error occurs after a certain time, also this amount
>> of time seems to be irregular. In Apache the same request with the
>> same binary keeps on running, but never finishes. The downloaded GML
>> file remains at a certain size, and no content is added anymore.
>> Any ideas what could cause this would be highly appreciated, or how
>> to go about debugging this problem further.
>> Best regards,
>> Bart
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050314/5b485fe2/attachment.html
