libcurl 7.12 and 7.13: unhandled exceptions in libcurl.dll
Bart van den Eijnden bartvde at XS4ALL.NL
Wed Mar 16 12:09:07 EST 2005
Hi Daniel,
but the fact that using libcurl 7.10.7 there is no problem, it does not
seem a Mapserver problem to me.
I have attached a memory dump of the crash. Maybe you can identify
something from that?
Best regards,
Bart
> Bart van den Eijnden wrote:
>> if I build my Mapscript on Windows against libcurl 7.10.7, Mapserver WMS
>> client works fine continuously.
>> If I build against 7.12.3 or 7.13.1 once in a while at a zoomin to a WMS
>> layer, I get an unhandled exception in php.exe, caused by an unhandled
>> exception in libcurl.dll.
>> Did anybody else experience this behaviour? And what is the recommended
>> version to use? Should we report this to the libcurl people?
> I'm not aware of specific issues with those versions of libcurl, but I'd
> say that it's defintely premature to report a problem to the libcurl
> developers until you have identified the source and nature of the
> problem and know for sure that it's in libcurl and not in mapserver.
> Just saying "unhandled exception" won't tell them much, just like that
> doesn't tell me anything either, they're just like us: they need a
> testcase to reproduce the crash and then they'll step in the debugger to
> identify the source of the problem, and they are not likely to download
> mapserver and compile it to test.
> Daniel
>   Daniel Morissette               dmorissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
Type: application/x-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050316/24873d26/libcurl.bin
