Carriage return/Line feed / space at end of line
Huub Fleuren hfl at HOME.NL
Thu Nov 10 04:29:58 EST 2005
Hi Frank,
For us it is both risky and too time consuming to upgrade (recompile) on
debian.
(i've been stuck on this for almost a week on this allready)
I suppose that it can be checked with any of your own testcases for
POSTGRESQL
I have some more info for you though.
The error was found after the truncated DATA statement in the
mapserv.log file appeared not to execute in pgAdmin if the lines end in
a table_name
compare:
"select blabla from table_name inner join table_name... " = ok
  inner join table_name... " = not ok
Is the next line is concatenated to the name in postgres?
(where a cr is whitespace and lf is not (once in postgres))
So it may be a bug in postgres, but than mapserver is the client: maybe
put the complete statement in one line, inserting whitespace where
appropriate?
Regards,
Huub
Frank wrote:
 >    try upgrading to 4.8 beta1
 >>a single white space at the end of every file seems to be necessary
 >>If you edit a mapfile on windows and then copy it to a linux machine
there is the danger that this white space is not there
 >>an ascii 10 (\n or LF ) is not considered to be whitespace it seems.
 >>a nascii 13 (\r or CR) is considered to be whitespace.
