Mapserver compilation with mygis on windows
Bart van den Eijnden BEN at SYNCERA-ITSOLUTIONS.NL
Mon Sep 5 05:00:04 EDT 2005
You need to download mysql and set the correct path in nmake.opt.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> =?ISO-8859-15?Q?Carsten_M=FCnchenbach?= <map at HYDRARGYRUM.DE> 09/05/05 10:43 am >>>
Hi all,
I manage to get MapSeerver compiled on Windows XP. It works fine without
the mygis option. But know I urgently need MapServer with MyGIS support.
Unfortunately I'm running into an error:
cl /nologo /MD /W3 /DDEBUG -Ic:/projects/gdwin32 -Ic:\projects\proj-
4.4.9/src -Ic:\projects\php-4.3.11/regex -DPHP_NO_ALIASES
-Ic:\projects\gdal-1.2.6/gcore -Ic:\projects\gdal-1.2.6/alg
-Ic:\projects\gdal-1.2.6/ogr -Ic:\projects\gdal-1.2.6/port
-Ic:\projects\gdal-1.2.6/ogr/ogrsf_frmts -Ic:\projects\gdal-1.2
.6/ogr -Ic:\projects\gdal-1.2.6/port  -Ic:/projects/curl-7.14.0/include
  -Ic:/projects/pdflib-6.0.0/pdflib      -Ic:\projects\mysql\include
-DHAVE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP
-DNEED_STRLCAT   -DWIN32 -D_WIN32   -DUSE_PROJ -DUSE_PROJ_API_H
-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF
-DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT -DGD_HAS_GETBITMAPFONT -DUSE_OGR
-DUSE_WMS_SVR   -DUSE_WMS_LYR  -DIGNORE_MISSING_DATA
-DENABLE_STDERR_DEBUG   -DUSE_GDAL   -DUSE_WFS_SVR -DUSE_WFS_LYR
-DUSE_WCS_SVR -DUSE_PDF   -DUSE_GD_ANTIALI
AS  -DUSE_MYGIS    /c mapjoin.c /Fomapjoin.obj
mapjoin.c
mapjoin.c(486) : fatal error C1083: Include-Datei kann nicht geoeffnet
werden: 'mysql/mysql.h': No such file or directory
NMAKE : fatal error U1077: 'cl' : Rueckgabe-Code '0x2'
What's going wrong? Ideas are ver appreciated!
Thanks,
Carsten
