Minor render bug...
Frank Warmerdam fwarmerdam at GMAIL.COM
Wed Sep 14 12:29:26 EDT 2005
On 9/14/05, Ned Harding <nharding at extendthereach.com> wrote:
> 1st, I'm not sure if I should report this here first or directly to
> bugzilla?
> With an embedded legend in RGBA mode, the symbols are showing transparent to
> the streets below.  The problem doesn't exist in PC256 mode.  It seems to
> only be a problem where a symbol came from a PNG file.
Ned,
You might be able to work around this problem by using
opaque PNG files but I do think it is a bug.  It is likely best
to submit a bug in bugzilla, and then advocate a bit on it's
behalf to get someone to fix it.
Best regards,
