Enums to strings
Frank Warmerdam warmerdam at POBOX.COM
Fri Sep 16 23:52:35 EDT 2005
On 9/16/05, Steve Lime <steve.lime at dnr.state.mn.us> wrote:
> I was thinking of just parking the array of strings right next to the enum in map.h, but the function sounds fine too. Were you thinking of something like:
> static char **msGetUnitsStrings()
>   static char **values = ...;
>   return values;
> or something like:
> static char *msGetUnitsString(int code)
>   switch (code) {
>     case 0: return "meters";
>     case 1: return "feet";
>    return NULL;
> The last element being the count is a good idea. We're doing that with the error codes in maperror.h but no where else I believe.
Steve,
Either way works, but the (very small) advantage of the second is that
it is easier to convert a enum code into a string into the middle of
an expression, such as the arguments to a debug or error message.   If
you do the second, I would encourage you to return "Unknown" or
something else safe to print as the default case instead of NULL.
Best regards,
