Enums to strings
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Mon Sep 19 22:11:47 EDT 2005
Oopps... I included the wrong version of the lookup function in my
previous email. It should be:
static char *msGetUnitsStrings(int code)
     static char *values[] = MS_UNITS_STRINGS;
     if (code >= 0 && code < _MS_UNITS_COUNT)
         return values[code];
     else
         return "unknown";
Daniel Morissette wrote:
> I like the idea of keeping the strings as close as possible to the enum
> in the .h file to help maintenance. How'bout the following approach that
> uses a #define to keep the strings close to the enum in the header file?
> In map.h:
> enum MS_UNITS {MS_INCHES, MS_FEET, MS_MILES, MS_METERS, MS_KILOMETERS,
> MS_DD, MS_PIXELS, _MS_UNITS_COUNT};
> #define MS_UNITS_STRINGS {"inches", "feet", "miles", "meters",
> "kilometers", "dd", "pixels"}
> Then the lookup function would be implemented as:
> static char **msGetUnitsStrings(int code)
>     static char **values = MS_UNITS_STRINGS;
>     else
>         return "unknown";
> Daniel
> Steve Lime wrote:
>> Option number 2 it is then (with unknown)...
>>>>> Frank Koormann <frank.koormann at INTEVATION.DE> 09/17/05 8:40 AM >>>
>> Dear all,
>> * Frank Warmerdam <warmerdam at POBOX.COM> [050917 05:53]:
>>> On 9/16/05, Steve Lime <steve.lime at dnr.state.mn.us> wrote:
>>>> I was thinking of just parking the array of strings right next to
>>>> the enum in map.h, but the function sounds fine too. Were you
>>>> thinking of something like:
>>>> static char **msGetUnitsStrings()
>>>>  static char **values = ...;
>>>>  return values;
>>>> or something like:
>>>> static char *msGetUnitsString(int code)
>>>>  switch (code) {
>>>>    case 0: return "meters";
>>>>    case 1: return "feet";
>>>>   return NULL;
>>>> The last element being the count is a good idea. We're doing that
>>>> with the error codes in maperror.h but no where else I believe.
>>> Steve,
>>> Either way works, but the (very small) advantage of the second is that
>>> it is easier to convert a enum code into a string into the middle of
>>> an expression, such as the arguments to a debug or error message.
>> just a thought since the original need for this function has been
>> template processing: The second option also would allow to add i18n in
>> the furture.
>> Regards,
>>         Frank Koormann
