Status of RFC 12?
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Apr 11 02:39:35 EDT 2006
I got back last week and had some old work to catch up with so I was
going to raise this issue again later this week.
I am going to add some other tests to see if I can sort out a
potential memory leak problem with Oracle connection poolingby using
unit tests (se http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1662).
Hopefully after this (if it works AND IF I can get a copy of oracle
spatial) more people will give a positive feedback.
Of course such an activity is going to take time so further commeting
or adoption will be delayed even more.
I'll try to raise the priority of this item to keep the discussion
going while it's fresh.
Best regards,
Umberto
On 4/10/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Steve Lime wrote:
> > Hi all: What's the status of the C unit test RFC? Last I saw there was a +0 from Frank and
> > little other dialog. I'd really like to get that to a point were folks are comfortable (a 'make test'
> > would be terrific) with it, commit things and see where it goes.
> Steve,
> I believe it takes two +1's to pass. If you were +1 and one other person
> was, then it would be a go. Note that +1'ing implies a willingness to
> do work if needed. Essentially taking on some degree of responsibility.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://osgeo.org
