Bug 1803, Upcoming breaking changes for 4.10.0-beta1
Tamas Szekeres szekerest at GMAIL.COM
Wed Aug 16 19:03:50 EDT 2006
Hi Sean,
Nice to hear from you again!
Setting colorObj is considered as safe since the raw copy of the
struct will copy all of the elements by value. The problematic members
are objects having subsequent object references.
Theoretically
myclass.label = new labelObj();
should be completely discouraged since the label member has already
been created.
One should get the label reference at any time, and play with it as he want.
Best Regards,
Tamas
2006/8/17, Sean Gillies <sgillies at frii.com>:
> On Aug 16, 2006, at 3:46 PM, Tamas Szekeres wrote:
> > Hi All,
> > According to the
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1803
> > and the agreement on the recent IRC meeting the following object
> > members will be marked as immutable on the SWIG interface:
> >   layerObj.metadata (hashTableObj)
> >   classObj.label  (labelObj)
> >   classObj.metadata  (hashTableObj)
> >   classObj.layer  (layerObj)          already marked as immutable in
> > mapscript.txt
> >   fontSetObj.fonts  (hashTableObj)
> >   imageObj.format  (outputFormatObj)
> >   labelPathObj.path (lineObj)         missing documentation about
> > labelPathObj in mapscript.txt should we expose at all?
> >   legendObj.label  (labelObj)
> >   legendObj.map  (mapObj)
> >   mapObj.symbolset (symbolSetObj)
> >   mapObj.fontset  (fontSetObj)
> >   mapObj.labelcache  (labelCacheObj)
> >   mapObj.reference  (referenceMapObj)
> >   mapObj.scalebar  (scalebarObj)
> >   mapObj.legend  (legendObj)
> >   mapObj.querymap (queryMapObj)
> >   mapObj.web  (webObj)
> >   mapObj.configoptions  (hashTableObj)
> >   webObj.map  (mapObj)
> >   webObj.metadata  (hashTableObj)
> > Generally there is no need to create these objects externally since
> > they have been created internally.
> > External creation of these members are unsafe, instead folks should
> > work with the already created objects by reading the members mentioned
> > above.
> > If I get no objections till Aug 17 10:00 (Central European Time) i
> > will change map.h and mapscript.txt accordingly so as to get it for
> > 4.10.0-beta1.
> > Regards,
> > Tamas
> Tamas,
> Don't forget all the colorObjs. Sooner you get word of this to the
> user community the better. Despite my warnings and heckling, code
> like this
>     $class->{label} = new mapscript::labelObj;
> is very common in user programs.
> Sean Gillies
> http://zcologia.com
