Feature request: n-band raster layer classification
Vincent Schut
schut at SARVISION.NL
Tue Feb 7 11:23:30 EST 2006
Frank Warmerdam wrote:
>On 2/7/06, Vincent Schut <schut at sarvision.nl> wrote:
>>Hello mapserver-developers,
>>In the near future, we are going to need raster layer classes based on
>>more than just the first band of a raster layer. 'We' means the small
>>company I'm working for, SarVision (www.sarvision.nl). We mainly develop
>>automated systems for tropical forest monitoring using satellite imagery
>>from several sensors, optical as well as radar. Besides that we offer
>>our customers/partners webgis access to the results through mapserver
>>and a dedicated webgis client.
>>One of our partners would like to be able to show a layer which is
>>actually a combination of 2 or more raster layers. As an example: show
>>all pixels that have an altitude of more than 500m or that are steeper
>>than 20 degrees in red, the rest in green. Now this is still one of the
>>simpler examples, and one of the prerequisites is that the
>>classification values (500m and 20degrees) are dynamically adjustable by
>>the user. I've been thinking of several workarounds for this, but of
>>course the most suitable way would be to implement raster classes based
>>on [band1], [band2], etc. instead of [pixel]. However, I'm afraid I
>>don't have the skills to implement this.
>>Could someone who is more knowledgeable on mapserver hacking elaborate a
>>bit on the feasibility of this enhancement? Would it be fairly trivial
>>to implement this, or almost impossible? Depending on our partner's
>>budget (which we don't know yet) we might even be able to sponsor the
>>implementation of this enhancement.
>Vincent,
>I will say that doing this will require a substantially different
>approach from the current raster classification logic. The current
>logic creates a "lookup table" for input raster values, classifies
>the lookup table, and then applies that lookup to the real raster
>values since the current expression handling code is rather slow
>to evaluate for each pixel.
>Depending on your needs, I would suggest implementing some
>sort of raster expressions as part of the GDAL VRT mechanism
>or perhaps even do the operates as a pre-processing step (invoked
>from mapscript) before mapping a resultant file.
>If you really want to do it directly in MapServer and you aren't
>too performance sensitive, I imagine we could come up with
>something.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
Folks,
having read Franks answer above, he is undoubtly right... I of course
have been thinking of several possible workarounds, on which I would
like to hear your ideas, and you might even come up with entirely new
ways of reaching my goal :-)
1: don't use mapserver cgi, build a mapscript based processor which
supports this kind of combi-raster-layer thing (but how?)
2: don't even think of implementing this at the server side. Implement
this at the client side. As I intend to develop a dedicated webgis
client in java for this partner, this would be possible, requesting the
several layers to be combined from mapserver cgi and using java2d/JAI to
calculate a new image.
3: fit the 2 layers to be combined into 8 bits each, and concatenate
each value into one 16 bit word. This gives us a 16-bit classifiable
layer, which we can (with the necessary inside knowledge) make classes
for that essentially create layer combinations. This effectively limits
us to 2 layers with 256 values/steps each
4: the same approach as (3), but using a palette and classifying on the
[red], [green] and [blue] values. This gives us 3 layers, but less steps
per layer than (3).
5: convert the rasters to one point dataset with a dbf field for the
value from each raster layer. Then use simple vector classification in
mapserver. Easy, but might be not so good performance-wise.
6: [more distant future] I read something (in the cvs changlogs I think)
about a new framework for plugin-based layertypes. Could a 'modeling'
plugin be developed which combines the (resampled) values of other
layers using a mathematical model (formula, logic operators, whatever,
something like the raster calculator in GRASS)? This probably is a more
long-term thing, but if the plugin framework would support something
like this, it would allow for some great and till now not even dreamed
of mapserver capabilities...
I'd love to hear some comments of you guys on these ideas...
Cheers,
Vincent.
