A Windows Build Tree for MapServer
Brent Fraser bfraser at GEOANALYTIC.COM
Wed Feb 8 14:00:18 EST 2006
Howard,
  I've made a batch file to build mapserver (and most dependencies) using
relative paths.  The only problem I ran into was with GDAL's reference to
JPEGDIR; it needs to be a full path. As I recall this is due to the fact of
a jpeg and jpeg\libjpeg dir in GDAL's frmts dir.  The relative path will
work for one, but is not valid for the other.  Perhaps Frank W. can help us
out with that...
Brent Fraser
GeoAnalytic Inc
Calgary, Alberta, Canada
----- Original Message -----
To: <MAPSERVER-DEV at LISTS.UMN.EDU>
Sent: Wednesday, February 08, 2006 10:42 AM
Subject: Re: [UMN_MAPSERVER-DEV] A Windows Build Tree for MapServer
> I don't know anything about PHP yet.  I was going to attempt to
> incorporate that in there, but I need to work with Assefa to do it.
> I would make all this available as a big zip file (emphasis on big).
> BTW, all of the mapscript tests pass with this configuration (dynamic
> everything).
> At 11:40 AM 2/8/2006, Bart van den Eijnden (OSGIS) wrote:
> >Hi Howard,
> >sounds interesting! I tried to use relative paths once but never got
> >everything to work that way.
> >I am missing PHP/Mapscript though in your bin output dir.
> >Is there an archive we can download to test this?
> >Best regards,
> >Bart
> >Howard Butler wrote:
> >>All,
> >>Assefa and I have been collaborating on a unified build tree for
> >>Windows binaries for MapServer.  This is a note to tell you what
> >>has been done so far and to propose some changes to the nmake.opt
> >>and makefile.vc files to streamline our build process a little bit
> >>and make it work nicely with the build tree.
> >>Building MapServer on Windows is a major PITA.  I have maintained
> >>something called the "kitchen sink," Assefa has maintained MS4W and
> >>PHP MapScript, and Perry also has a binary set.  I would like to
> >>try to collect things together a bit so they all build off of
> >>common stuff.  The reasoning behind this is to make it a bit easier
> >>for folks to swap libmap.dlls to get functionality from one build
> >>or another (mostly thinking of SDE, Oracle, and MrSID) into various
> >>.exe and MapScripts.  I do not know whether or not this dream is
> >>realistic or not.
> >>In any case, I have been working on a build tree at
> >><http://hobu.stat.iastate.edu/mapserver/build_output/assefa>.  It
> >>contains almost everything for a full GDAL and MapServer build.
> >>Everything has been brought up to date.  Everything has been built
> >>dynamically with /MD.  GDAL is built with plugins for SDE, Oracle,
> >>and MrSID.  The intent is for someone wishing to build their own
> >>MapServer to just grab the build tree, tweak nmake.opt to give the
> >>path to it and do nmake /f makefile.vc and have it build up
> >>everything all at once.  This is with MSVC 7.1, so it obviously
> >>isn't for everyone, but I think it could go a long way in making it
> >>much easier for folks to build things without having to worry about
> >>the bazillions of little issues that crop up along the way.
> >>To make this work, I have done some slight modifications to the
> >>nmake.opt and makefile.vc files.  These include setting things up
> >>to use relative paths, and creating install targets for the
> >>mapscripts and .exe/.dll so they are collated into the ../bin
> >>directory.  I would like to go through nmake.opt and make some
> >>changes to make things be relative to this build tree.  I would
> >>also add some things like SWIG and JAVA_HOME to make it easier to
> >>have MapScript build targets.  I would make these changes in CVS
> >>HEAD.  I would also create/edit the Win32 build HowTo to describe
> >>how to use this.
> >>If people want to me to write an RFC to describe this stuff I can do so.
> >>As an aside, I would really like to reconfigure Oracle and SDE to
> >>use the plugin architecture.  They seem to cause no end of requests.
> >>Using plugins for these should make our build layout/setup much
> >>easier. I plan on pursuing this for the Hawaii 5-0 release.
> >>Howard
> >OSGIS, Open Source GIS
> >http://www.osgis.nl
