RFC 11: Curved Labels
Bill Binko
bill at BINKO.NET
Thu Feb 16 13:53:41 EST 2006
Guys: this all sounds wonderful! Can I see some images from it? Or do
I have to apply the patch and try it out
Benj Carson wrote:
>On Thursday 16 February 2006 05:44, Stephen Woodbridge wrote:
>>Great work guys! I look forward to this.
>>I couple of comments, which might be too detailed for the rfc, or not.
>>1) What is the behavior when the label extends beyond the feature?
>In the proposed patch this case is handled by comparing the length of the
>label to the length of the longest line segment in the feature. If the
>label is less than 1.5 times as long as the feature then it is drawn,
>otherwise it is skipped (unless the label is forced, in which case it is
>drawn anyway). The value of 1.5 is simply hardcoded at the moment. It
>seemed to give me pretty decent results, but it may need some adjustment.
>>2) Would it be appropriate to be able to control long labels on short
>>features? - I know we don't do this today so it might be outside of
>>scope.
>This is certainly feasible, but it is beyond what is currently done in the
>proposed solution.
>>3) What plans if any do you have to deal with right side up-ness
>>of a label that is curved, I proposed a fast algorithm for that in the
>>bug :) The problem being that while the first character rendered might be
>>right side up, the remaining might be mostly upside down so a quick scan
>>of the feature is needed to determine what is right side up.
>I have integrated an algorithm similar to the one you described on the bug
>page into the patch. Instead of taking the cross product of each segment
>with a vector perpendicular to the map, I'm comparing the x values of the
>endpoints of each segment that is covered by the label (which I think is
>equivalent to taking the cross product in terms of determining direction).
>If most of the segments are left to right, the label can be drawn on it
>directly and it will be mostly right-side up (since this is what GD
>expects). If the feature is mostly right to left, the line is processed in
>reverse order producing a label path that progresses left to right.
>So, the whole feature *is* scanned in order to determine which way is up,
>and the results are much better than the initial implementation. The
>algorithm can still produce some so-so results if there is one long left to
>right segment and several right to left segments (e.g. in a line shaped
>like the number "7"), but for the most part nothing is completely upside
>down.
>For the nitty-gritty details: All of this is in mapprimitive.c in the
>msPolylineLabelPath() function once the patch is applied.
>Benj
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060216/91b19e8b/attachment.html
