Layer Virtualization and LayerCloseConnection vs LayerClose (SDE issues)
Howard Butler hobu at IASTATE.EDU
Fri Feb 24 15:30:17 EST 2006
Jani,
I found a problem with the SDE driver where we weren't closing out
layer information.  The layer virtualization has two methods,
LayerCloseConnection and LayerClose.  In SDE, they were both being
used, and LayerClose was set to a NoOp function that was just
returning success.  This wasn't allowing the SDE driver to free up
its layer information and decrement the connection pool when a layer
was closed.
I have fixed this by commenting out the definition of the
layer->vtable->LayerCloseConnection method in the
msSDELayerInitializeVirtualTable method, replacing the NoOp method to
use our regular msSDELayerClose method, and removing the NoOp method
completely.
Was there a reason why we took this approach in the SDE driver?  I
vaguely remember possibly even asking for a LayerCloseConnection
method, but I'm not sure.  Do you have any recollection?  I think the
intent for layers using connection pooling is that each driver's Open
and Close methods will take care of that and it wouldn't be needed in
the layer virtualization.  Maybe that is not the case for a plugin
layer that might be providing its own connection pooling?  Is that
why there are two methods?
I think we could get by with just having LayerClose and LayerOpen
deal with connection pooling issues entirely and not have to worry
about them in the layer virtualization, but I'm not a 100% sure.  For
one thing, I'd like to see the connection pool bubbled up to
MapScript at some point, but I don't know where that should happen --
in the layer virtualization or through some other mechanism.
Howard
