antialiasing stuff
Steve Lime steve.lime at DNR.STATE.MN.US
Fri Jan 13 14:55:42 EST 2006
This should be doable "as is". Just set TRANSPARENCY ALPHA and point
to the right image in your style or symbol definition. All the fuzzy brush
support does is do this programatically.
I believe I've tested this before using an image or two that Sean had created
while fixing another bug.
Have you tried it and it doesn't work?
Steve
>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 12:59 PM >>>
Steve,
what would it take to support rendering lines with custom symbols
that have alpha transparency in them?  We would like to be able to
make our own brushes that work in the same way that fuzzy brushes
work, but we pre-render them and access them as symbols.  This would
allow finer control over styling without having to tweak mapserver
code to get the desired effect :)
Cheers
Paul
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
