PostGIS Bug 1587 (was Release Candidate 3)
Jerry Pisk jerry.pisk at GMAIL.COM
Thu Jan 19 13:13:10 EST 2006
I wouldn't say misgivings, the code will work either way. The per
layer code is arguably cleaner even though it's less efficient. But
there really should be something like LayerInitialize (is there?) that
will be called when each layer type is first loaded/instantiated,
where layers can put their initialization code. For PostGIS this
should be in there.
Jerry
On 1/19/06, Sean Gillies <sgillies at frii.com> wrote:
> You're right. I'll back out the commit if you have misgivings about it.
> Sean
> On Jan 19, 2006, at 10:35 AM, Jerry Pisk wrote:
> > This is the client machine bit order, is there really a need to store
> > it locally for each layer? You really only need to find a way to
> > initialize the variable before any PostGIS layers are open. Even the
> > existing code would work fine, there will be multiple writes to the
> > global variable but they will all write the exact same value to it so
> > it would not matter in which order they come in relation to reads from
> > it.
> > Jerry
> > On 1/19/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> >> A big thanks from Italy!
> >> So is it gonna make it for 4.8?
> >> Regards,
> >> Umberto
> >>> I just applied Umberto's patch to 4.8 and python/tests/cases/
> >>> pgtest.py runs just fine. Without this patch, it is possible that
> >>> users could get into trouble connecting to separate databases from
> >>> the same map if byte order differs between the DB platforms.
> >>> Sean
> >>> On Jan 19, 2006, at 8:10 AM, Steve Lime wrote:
> >>>> I see no one from Refractions has commented one way or the other.
> >>>> It would =3D
> >>>> be nice to get Paul or one of his technical folks to at least bless
> >>>> the =3D
> >>>> patch before modifying their module. I think someone from that
> >>>> group still =3D
> >>>> hangs out here occationally...
> >>>> Steve
> >>>>>>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 01/19/06 8:20 AM
> >>>> Hi,
> >>>> do you think this bug could be fixed before 4.8 gets out?
> >>>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D3D1587
> >>>> It's been there for a month and it looks like a trivial patch to
> >>>> me. =
> > I
> >>>> have tested the patch on 4.6.2.
> >>>> Best regards,
> >>>> Umberto
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com/news
