MapServer and Sensor Observation Service
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Fri Jan 27 14:48:12 EST 2006
Daniel,
I think the issue here is would any of the existing community benefit
from this, be able to use it, etc or not. It seems like this would add a
lot to the documentation and complexity to mapserver from the point of
view or newbies trying to learn things and from testing and release
management.
So if a bunch(?) of other users need this functionality in mapserver, I
guess I would be OK with it, but my gut based on the description and my
needs today, would say make it a separate project built on top of
mapserver. It seems you have had similar concerns because you are asking
these questions and thought up these scenarios.
I think this gets back to the need for a mapscript like API for "C" that
is stable and that other can build C-based applications on.
My 2 cents,
  -Steve
Daniel Morissette wrote:
> Hi,
> We are working with Tom to implement a Sensor Observation Service (SOS).
> Since they already have a bunch of WMS/WFS services based on MapServer,
> they would like to have this as an extension to MapServer, with the same
> configuration mechanism that their administrators are already used to.
> However, the SOS is in this grey area of features that may or may not
> belong in MapServer depending on how we look at them.
> So we are considering two options on which we would like to have your
> opinion:
> 1- Implement SOS as a new service type supported by MapServer (i.e.
> mapsensor.c) just like the current WMS/WFS/WCS support, an optional
> feature that could be enabled/disabled at compile-time.
> 2- Create a separate project independent of MapServer for the SOS. It
> would be built on top of map.h and libmap, but would not be part of the
> MapServer source and distribution.
> In both cases, the result would be more or less the same: a SOS that is
> configured via a the same MapServer mapfiles that are used for WMS/WFS,
> and that uses the same data access methods from maplayer.c... the
> question is really whether we think that this feature belongs in
> MapServer (#1) or not (#2).
> Daniel
