msLayerOpen and msLayerClose
Frank Warmerdam
warmerdam at POBOX.COM
Tue Jun 6 10:36:50 EDT 2006
Howard Butler wrote:
> In addition, for some drivers, opening and closing the layer many times
> can have significant overhead. Would it be beneficial to have a
> create/delete pair that actually does the construction/destruction of a
> layer? Could we somehow ensure that this only happens once through the
> life cycle of a mapObj (or explicitly created/destroyed through
> MapScript)? Would this improve the situation at all or just push the
> problem somewhere else?
Howard,
Well, it's a bit of a hack-around in a sense, but setting the connection
pooling on for such a layer would avoid the extra overhead even if the
high level code wasn't too careful about preserving connections over a
whole render.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
