Pre-RFC, pulling rendering/labeling parameters from attributes...
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Tue Jun 6 21:05:55 EDT 2006
Ok, glad I read this one before posting the exact same thing! only I
would have done my example like:
  SIZE [sizeattribute]
  ANGLE ([angleattribute] - 90.0)
  LABEL
   TEXT ("Label: " . [labelattribute] . ".")
  END
This would require a lot of changes, but could be fully backwards
compatible.
-Steve W.
Jerry Pisk wrote:
> How about doing something similar to format strings? For example:
> SIZE "{sizeattribute}"
> ANGLE "{angleattribute}"
> LABEL
>  TEXT "Label: {labelattribute}."
> END
> You would need a way to disntiguish between an attribute name and an
> actual value anyway. And ity would be nice to support substitutions in
> all values when we're at it, even things like COLOR, OFFSET and so on.
> Jerry Pisk
> On 6/6/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
>> Hi all: Before running off and doing an RFC I wanted to gather some
>> feedback. Currently we do
>> support pulling things like angle or size from an attribute. Works
>> fine but is clunky in many ways
>> since you see things like angleitem and angleitemindex in the
>> structures. Adding more support
>> for will just add more needless complexity (I could see folks wanting
>> to set colors, start angles
>> and other stuff).
>> Anyway what might be nice would be to write fragments like:
>>  STYLE
>>    SIZE 'sizeitem'
>>    ANGLE 'angleitem'
>>    COLOR 0 0 255
>>  END
>> We could then use an hashTableObj called items to track the various
>> values to pull from attributes.
>> At parse time the hash would contain the item names. msWhichItems
>> could turn those into array
>> indicies (can the hashTableObj handle arbitrary types?) for speed.
>> Then the rendering code could
>> do a quick lookup to decide whether to pull from an attribute or not.
>> It would be very easy to add support for new parameters then, just
>> tweak the high-level rendering
>> code (before handoff to native drivers). In MapScript we'd need a
>> method to set a style or label
>> items (e.g. $style->setItem('angle', 'myAngleItem');) or just use the
>> hashTableObj interface.
>> The bad? Syntax change (I'd leave labelitem and classitem alone) so
>> this would be a good 5.0 feature.
>> There might be a perforance hit with the high number of hash lookups.
>> Worth thinking about?
>> Steve
