Checking number of attributes in tile4ms
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Thu May 11 00:38:32 EDT 2006
Mateusz Łoskot wrote:
> Hi,
> Recently, I was fixing some GDAL issue reported by Bart
> (http://bugzilla.remotesensing.org/show_bug.cgi?id=1144)
> and I added tests of attributes scheman in input layers to ogrtindex
> utility.
> As discussed on Bugzilla
> (http://bugzilla.remotesensing.org/show_bug.cgi?id=1144#c4)
> it's recommended to check number of attributes, and if number is same,
> schema of attributes.
> I noticed that tile4ms utility does not compare number of attributes, so
> I applied small fix. So, tile4ms handles differences in attributes of
> input layers exactly in the same way as ogrtindex.
> Is there any interest of such changes?
> If there is, I can provide a patch.
> Cheers
Mateusz,
I read through the bug and it looks like you have it correctly
understood. I think this would be a good additional check for tile4ms.
Please prepare a patch and attach it to the bug or open a new bug
against tile4ms and attach it to that. I think Steve Lime will probably
be assigned to it by default. It will be good to have ogrtindex and
tile4ms behaving the same way.
-Steve W.
