Dynamic libmap.so
    Howard Butler
    hobu at IASTATE.EDU
    Thu May 18 09:24:21 EDT 2006
All,
After some futzing, I was able to build a dynamic libmap on OS X
using the "make shared" target in the Makefie.  I was wondering if
there were historical reasons why we don't always build a dynamic
libmap.so, and why we normally do static linking for programs like
mapserv and shp2img.  Static building happens in MapScript as well,
and this complicates the MapScript build process, forcing us to use
the "mapscriptvars" hack for TCL, Perl, Python, and Ruby to pick up
libs, definitions, and header files.
Some questions about the MapServer build process:
- If MapServer is to have a C API, is it expected that this would be
built and linked to applications dynamically?
- Will a dynamic libmap build simplify our MapScript build process?
MapServer build process?
- Are there performance/memory footprint gains to be had from a
dynamic libmap.so?
Howard
