New bug owner for mapscript needed
Sean Gillies sgillies at FRII.COM
Fri May 26 12:15:39 EDT 2006
Hey all,
I've got a brand new gig starting in June that, while geospatial in
nature, won't be making much direct use of MapServer, and won't allow
me much time to respond to mapscript bugs. My time as owner of the
SWIG mapscript Bugzilla component is done. Maybe you'll want to
reassign to one person, or split it up by language, that's up to you.
And since I don't foresee making many more big contributions to
MapServer, I will resign my seat on the TSC as well, effective June
12. I'd like to retain commit privilege in order to make the odd bug
fix here and there, but that's about the extent of my future
involvement. I won't be supporting the Python test framework, or the
mapscript.txt doc. To me, these are failed efforts, and the search
should begin for something better.
I'll stick around for Bugzilla through the end of June, so that a new
component owner can be found, and I will of course be happy to assist
that person or persons in taking over.
cheers,
Sean
Sean Gillies
http://zcologia.com
