RFC-18: Encryption of passwords in mapfiles
Frank Warmerdam warmerdam at POBOX.COM
Fri May 26 15:37:16 EDT 2006
Daniel Morissette wrote:
> Do you see this as a blocker issue?
Daniel,
Not necessarily.
> Perhaps the msDecryptString() function could look for a pair of { + },
> and then verify that all chars in the block are valid base 64 encoding
> chars before proceeding with decryption. That should significantly
> reduce the chances of a false match. What do you think?
I think this would be a great idea.
> Another alternative would be to only allow encrypting the full
> connection string in one chunk, but it would be harder to maintain
> mapfiles this way.
Right.  I think it is much preferrable to just apply it to the password.
> I liked PEM (base 64) encoding because it is apparently the most compact
> way to encode binary data using printable chars. It increases the data
> size by a ratio of 4:3 instead of 2:1 for hex encoding. I had also found
> an implementation covered by a MIT license at
> http://base64.sourceforge.net/.
I can't imagine efficiency is very important in this context.  And a more
limited grammar of characters might make the validation described above
safer.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
