MapServer and GPL dependencies...
Steve Lime Steve.Lime at DNR.STATE.MN.US
Wed Nov 8 15:13:19 EST 2006
It's not set in stone, there was quite an uproar on the mailing list and
the
main developer had not chimed in that I had seen. Perhaps a dual
license
is in the cards.
Steve
>>> Howard Butler <hobu at iastate.edu> 11/8/2006 7:57:19 AM >>>
It's unfortunate that they didn't go LGPL...  I'm not a licensing
zealot, but it might be a problem for some folks using MapServer.  I
suppose our transition to AGG would be gradual and people might
initially have the option of not using AGG.  I'm concerned, however,
that having parallel renderers, with one being functionally and
qualitatively much better than the other will cause all of the
development momentum to move toward AGG.  If that happens over the
course of a couple of releases, do we effectively limit our licensing
and deployment to GPL?
Howard
On Nov 8, 2006, at 12:04 AM, Steve Lime wrote:
> Hi folks: We've been looking at AGG as a possible alternative
renderer
> to GD for some time now. One thing that has just popped up in the
AGG
> camp is a license switch with it's latest release. It is now GPL.  I
> don't believe there's a reason to not consider AGG because of that
> (PostGIS is GPL), correct?
> Steve
