MSAutotest WxS on windows
Normand Savard nsavard at MAPGEARS.COM
Thu Oct 12 16:01:40 EDT 2006
Normand Savard wrote:
> I corrected most of the problems on Windows with some help (Tom
> Kradilis and Assefa).  There are still some issues and/or questions.
> I describe in the following paragraphs what these issues are.
> Norm
> wxs:
> wms_sld.map
> wms_get_map_multi_layers_one_sld_on_all_layers.png (line thichness
> changes on Windows, MS1937)
> wms_get_map_multi_layers_one_sld_on_one_layer.png (same)
> wms_get_map_line_multi_symbol_text_sld.png (same)
> wms_get_map_mark_symbol_sld.png (star symbols are shifted a bit on
> Linux see file attached)
> wms_time_pattern.map
> wms_time_pattern1a.png (removed because of unsupported YYYYMMDD format
> on Windows, see MS970 and MS1926)
> wms_time_pattern1b.png (same)
> wms_time_pattern1c.png (same)
> wms_time_pattern1d.png (same)
> wms_time_pattern2d.png (same)
> tomk_workshop.map
> wms_get_feature_info_raster.html (HTML response is different from GML,
> bug MS1927)
> wms_get_feature_info_raster.gml (same)
> wcs_simple.map
> wcs_16.tif (image is stretched a bit on Windows and Linux, it seems to
> be a rounding issue.  I didn't update it in CVS)
> wcs_bilinear.png (same)
> wfs_filter.map
> There is a rounding issue for the following tests on Windows (see bug
> MS1935):
> result\wfs_filter_greater_than_or_equalto.xml
> result\wfs_filter_isbetween.xml
> result\wfs_filter_isbetween_and_not_isequalto.xml
> result\wfs_filter_isequalto_or_isequalto.xml
> result\wfs_filter_isequalto_or_isequalto_reverse.xml
> result\wfs_filter_isgreater_than.xml
> gdal
> average_rgb.map (see bug MS1932)
> reproj.map  (see bug MS1933)
> wld_upsidedown.map (see bug MS1934)
> other maps:  small changes so I didn't update in the CVS
> misc
> rfc14.map (see bug MS1936)
> There are small differences (probably rounding).  So I just validated
> and did not update in CVS.
I said "I corrected most of the problems on Windows with some help (Tom
Kradilis and Assefa)." but I forgot to include Frank as well.  Sorry.
Norm
