RFC-24 Mapscript memory management: call for votes
Tamas Szekeres szekerest at GMAIL.COM
Mon Apr 2 09:40:31 EDT 2007
Steve,
I have no doubt that you are a TSC member. The only confusion I have
is that how many TSC member vote is required to pass the proposal
whether the proposer is a TSC member or not.
Nevertheless, having another +1 from Howard the current state of this
voting has become obvious.
Best regards,
Tamas
2007/4/2, Stephen Woodbridge <woodbri at swoodbridge.com>:
> Tamas,
> I am on the TSC. RFC1 only reflects the founding members I was added
> later. You will see me listed in RFC23. It is not easy to find a current
> list of TSC members, we should probably fix that.
> -Steve W.
> Tamas Szekeres wrote:
> > Umberto,
> > According to #6 only members of the Technical Steering Committee's
> > votes will be counted so you should wait for another +1 from a TSC
> > member before announcing the results and committing the changes,
> > Best regards,
> > Tamas
> > 2007/4/2, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> >> Currently the voting request has been on line for over a week and it
> >> is going as follows:
> >> +2 (me, Stephen Woodbridge)
> >> +0 Frank Warmerdam
> >> I have reread RFC1, and according to item 7 I can consider it approved
> >> even though I'd hoped to see some more votes.
> >> Anyway, I'll update the rfc with a compatibility section to comply
> >> with Stephen's requirements and then I'll start committing changes. I
> >> should be done by next week (sunday 14) because of Easter and some
> >> other projects' deadlines in this week.
> >> Thanks to all,
> >> Umberto
> >> On 3/24/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> >> > I took some time to update the RFC text at:
> >> > http://mapserver.gis.umn.edu/development/rfc/ms-rfc-24
