Drawing Raster Query Results
Daniel Morissette dmorissette at MAPGEARS.COM
Wed Apr 25 16:44:57 EDT 2007
Steve Lime wrote:
>>>> On 4/23/2007 at 4:09 PM, in message <462D2097.3050808 at pobox.com>, Frank
> Warmerdam <warmerdam at POBOX.COM> wrote:
>> The drawing a query layer for a map result doesn't work properly, as
>> documented in:
>>    http://trac.osgeo.org/mapserver/ticket/2069
>> The question, to my mind, is whether it makes sense to try and draw point
>> features from a raster query result on a map, and if we did so how do we
>> differentiate styling used for the raster from styling used for the query
>> results which are a very different sort of data.
> You could use the color specified in the queryMapObj to set pixel values for each
> cell stored in the result set. Wouldn't be too hard. If the user is selecting pixels
> they should get back yellow pixels in the query map. That's for the "hilite" mode.
> Then there's the "selected" mode where only the queried pixels would be displayed.
> In effect you'd get a mask which might look cool if there were enough pixels affected.
This sounds like a good solution for ticket 2069, or am I missing something?
>> I'm tempted to modify msDrawQueryLayer() to do nothing raster layers, but to
>> issue a debug message indicating that the layer is being skipped since
>> drawing raster query results is considered an unclear request.
> I think there are reasonable actions we could take for raster queries. It's more a
> matter of priorities I guess. Could always note a desire to address in the future
> and punt for now.
I guess skipping the layer is a valid quick fix if a better solution
can't be implemented now... but then the final solution would likely be
what Steve suggested above, right?
Daniel
Daniel Morissette
http://www.mapgears.com/
