msautotest on Windows (buildbot) for MapServer 5.0
Tamas Szekeres szekerest at GMAIL.COM
Wed Aug 29 17:42:42 EDT 2007
Normand,
I've added a ticket
http://trac.osgeo.org/mapserver/ticket/2273
with more information included in the projection issue
Best regards,
Tamas
2007/8/28, Normand Savard <nsavard at mapgears.com>:
> I checked the reason why the msautotest failed on buildbot for MapServer
> 5.0 (szekerest-vc80-ful).  Most of the tests that return text file (xml,
> gml, html) failed because they have a "crlf" on each line and the
> expected results contain only "lf".  I modified the msautotest python
> script to process the "crlf" to "lf".
> I noticed that the wxs/sld tests failed because the projection 42304 is
> not found (see the error message below).  The projection is defined in
> the map file as:
> PROJECTION
>  "init=./data/epsg2:42304"
> END
> The epsg2 file is really in the data directory.  I have no idea right
> now why it doesn't find the projection file on this Windows machine.
> The Windows machine at our office didn't meet this issue.
> Finally some of the tests failed because of floating point rounding
> rules difference between Windows and Unix.  These tests need to be
> validated visually and move to the expected directory.  They are:
> in gdal:
> in misc:
> Norm
> Response of the map server:
> <ServiceException>
> msProcessProjection(): Projection library error. no options found in
> &#39;init&#39; file
> </ServiceException>
