agg changes
Paul Spencer pspencer at DMSOLUTIONS.CA
Thu Aug 30 10:10:54 EDT 2007
No worries then!  I still think it is a good idea to have some sort
of cartographic needs assessment post 5.0.  While I am not a
cartographer, I would be willing to commit time to helping out with
such a task and would be able to involve others at DMSG to a limited
extent as well, more if we can align it with projects of course.
Cheers
Paul
On 30-Aug-07, at 9:58 AM, Daniel Morissette wrote:
> Paul,
> Unfortunately at a few days from the release I think it's too late
> to strip out stuff. Your reasoning makes sense, but in the interest
> of getting a release out I have to say "no more changes in 5.0".
> Daniel
> Paul Spencer wrote:
>> Steve,
>> I'd like to suggest defering cartographic enhancements (by which I
>> mean additional keywords in the map file to specify more advanced
>> cartographic options) until post 5.0.  I think, since you are
>> moving from 4.x to 5.x and *can* make some changes that are not
>> necessarily backwards compatible, that you should consider
>> removing things from the mapfile at this point that don't work or
>> won't be supported in order to establish a minimum baseline which
>> the 5.x series can build on by adding new features without having
>> to make an incompatible change in the next version.  Essentially,
>> I am advocating stripping out as much as possible/practical, and
>> then adding new stuff post 5.0.
>> Looking forward to 5.2, I think it would be really beneficial to
>> start a dialog with the user community on cartographic needs and
>> try to establish a set of requirements that can be built towards
>> in the 5.x series.  I know that MapGuide has implemented point and
>> line support for a massive USGS cartographic standard and has some
>> very impressive demos of the new cartography.  There is also a
>> large document describing the cartographic needs of the Canadian
>> national dataset folks.  There are probably other 'standards' out
>> there too.
>> AGG has given mapserver an excellent foundation to build on for
>> premium cartography, and I think it would be a mistake to leave
>> stuff in mapserver 5.0 that we may regret post 5.0.
>> Cheers
>> Paul
>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>> |Chief Technology Officer                                         |
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> Daniel Morissette
> http://www.mapgears.com/
